15 years agohow to control the audio data in WM8731 DE2 board
Hello everyone Why is there is still sound that produced even when i remove pin AUD_ADCDAT and AUD_DACDAT from my project(i am using block diagram arrangement). I've set up the audio codec c...
15 years agoHi,
try to MUTE the MIC input with Analog Path set to: 000100X00010010. With your configuration the ADC is using Line-In so you should not need MIC input. And if you don't mute it, it will be added to the DAC analog output signal (I think).
