ThangND
4 years agoHow to boot Nios II from EPCS flash and run the program from SDRAM in board DE0-Nano
I'm using the DE0-Nano board and I'm trying to program my Nios II application code via the EPCS flash and run it from SDRAM.
Here is what I've done:
1. Qsys:
I've set the res...
- 4 years ago
You may check on this similar previous case https://community.intel.com/t5/FPGA-SoC-And-CPLD-Boards-And/Can-t-get-DE0-nano-board-to-boot-from-EPCS-with-NIOSII-code/m-p/698479 probably can help you out.
Sheng
ShengN_altera
4 years agoHi,
Sheng
