GabrielMarco
1 year agoHow do i solve OpenCL Platform?
I've been trying to use oneAPI for over a month, but it always gives this error: OpenCL platform ID is empty OpenCL platform name is empty Failed to find any of these OpenCL platforms: Intel(R)...
BoonBengT_Altera
Moderator
1 year agoHi @GabrielMarco,
Thank you for posting in Intel community forum, hope all is well and apologies for the delayed in response.
I believe you have run the setvars.sh to setup the environment however the error are still the same.
Just to check have you run the aocl install before? If you have done so please do check the installation by running the aocl diagnose and share the result here for us to better understand the situation.
As for the error in ac_fixed.hpp, if the installation is correct it, usually it should be in the following path: <installation_path>/intel/oneapi/compiler/latest/include/sycl/ext/intel/ac_types/
Hence you could verify the following path.
Hope that clarify
Best Wishes
BB
