TarikTec
5 years agoHow can I update my Quartus Prime Standard 17.1.0 to QPS 17.1.1?
Whenever I want to launch a an already existing project that is made in Quartus Prime Standard 17.1.1 as you can see below:
How do I update to the this version ? I found on the link this ver...
- 5 years ago
I just downloaded this and follow the instructions above and it works.
TarikTec
5 years agoI just downloaded this and follow the instructions above and it works.
Nurina
5 years agoGlad your problem has been solved and thank you for sharing your solution. I will put this case to close pending. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
Nurina
P/S: If you like my comment, feel free to give Kudos. If my comment solved your problem, feel free to accept my comment as solution!
