NEvan4
6 years agoHow can I increase the font and ribbon size in the Intel FPGA Monitor Program 18.1?
The font and ribbon sizing in the FPGA Monitor Program is very tiny and hard to see on my computer, but I don't see a way to increase it. I am running on Windows.
Vicky1
6 years agoHi,
Have you resolved the issue?
Have you tried solution provided in last post? please share here observation.
May I know any update or Should I consider that case to be closed?
Vicky
- NEvan46 years ago
The program does work alright on the university machines, but on my personal laptop is where the issue is. I am using a surface pro 2, and so the high DPI might be a cause. However this is the only program I've run into where I have this problem on it. Do you know of a way to increase the size only for the Monitor Program?
Nolan
- Vicky16 years ago
Hi Nolan,
I couldn`t find as such settings here. we can try remaining options like,
- Try to revert Default windows arrangement by Using 'Windows' menu( refer attachment ).
- Try to compare the display resolution with university machine & apply to the personal laptop.
- Uninstall & delete the current installation files & Download newly fresh setup of University monitor program & install again.
Vicky
