14 years agoHelp writing Verilog code for addition - Calculator using FPGA
Hi. I am doing a project - Calculator using FPGA board.. however, i am facing problems writing the Verilog code for addition of numbers.. the input is in ascii code, which i need to convert into...
14 years agoBy nature, all digital logic quantities are binary. Decimals can be e.g. presented as binary coded decimal (BCD) numbers or 1 out of 10 decoded signal. You should specify the function of intended logic more exactly.
