14 years agoHelp writing Verilog code for addition - Calculator using FPGA
Hi. I am doing a project - Calculator using FPGA board.. however, i am facing problems writing the Verilog code for addition of numbers.. the input is in ascii code, which i need to convert into...
14 years agoFirst I would suggest you create look up table that converts ascii to binary and back again. The addition of binary numbers will be straight forward.
