14 years agoHelp with UART core
Hi, I'm not sure if i placed this topic here correctly. Well anyway, i need help. So I was able to make codes for NIOS II that will receive serial signals from my hyperterminal to the Altera DE2 boar...
14 years agoDo you use a null modem adapter to properly route the Tx and Rx signals in the tests you tried. My gut feeling tells me that if you connected the DE2 to a PC with hyperterminal and you connected the RFID reader to the PC with hyperterminal then you would need to cross the Tx and Rx signals when connecting the RFID to the DE2.
