11 years agoHelp with Basic Concept Please
Hello folks, Having lots of trouble understanding a simple concept. I would like to know how the data register works for this UART. From the Data sheet, this is what info i have:
device RS-232 UART configuration Two 32-bit mapped registers input/output Either address base 0x10001010 address map address r/w description base R/W Data Register 23:16 - Number of characters available to read (after this read - see Notes) 15 - read data valid 9 - parity error 7:0 - the data itself base+4 R/W Control Register 23:16 - Spaces available for writing 9 - Write interrupt is pending 8 - Read interrupt is pending 1 - Enable write interrupts 0 - Enable read interrupts Now a simple question, Let's say i want to read the UART of the Board, i wrote a short code in C for (Altera Monitor Program) but i get a garbage as input. Using a Terminal on PC to send some characters, and would like to display them on the HEX Disp. Here is what i tried to do: ------------------------------------------------------------------------------ mask = ((*RS232_UART_DATA)&0xFF00FF); // Reading the UART and masking some bits HEX=mask; // Storing data to be written to hex ------------------------------------------------------------------------------ The issue is before i even get to send a character from the PC side, i start seeing garbage on HEX. And when i do attempt to send a character, the HEX shows more garbage. At least i can be sure the data is being transmitted, but i have no knowledge on how to mask the DATA Register appropriately. ANY HELP WOULD BE APPRECIATED!!!! Thanks.1 Reply
Assuming your baud rate, etc settings match between the PC and FPGA board, you need to check the data valid bit. You only have input data when that bit is set. If it isn't set, come back later and check again. If the data valid bit is set the number of characters field will tell you how many bytes you can read before waiting for data valid again. The code you have doesn't do this.
