17 years agoHelp using SDRAM with SDR_SDRAM controller
Hello, I use DE2 SDRAM with SDR_SDRAM ALTERA controller(vhdl files). I try to write 640*480 *16 bits data to SDRAM. Wich commands have I to write to controller and in wich order? Thank you.
17 years agoIt's unclear, if you want to access the SDRAM from NIOS II C code or VHDL.
