csnsssn
2 years agoHelp Needed: Error "nios2-elf-as.exe: not found" while Assembling Nios II Program
Hello everyone, I'm encountering an issue while trying to assemble a Nios II program using the Nios II Command Shell. The specific error message I receive is: ``` nios2-elf-as.exe --gstabs -I "C:/...
aikeu
2 years agoHi csnsssn,
I am not familiar about the command(nios2-elf-as) which you are trying to run, it is the nios2-elf-ar as below?
Can you try the run other command in the Nios II terminal like sof2flash and see if it is being recognized by the terminal?
Aik Eu
