csnsssn
2 years agoHelp Needed: Error "nios2-elf-as.exe: not found" while Assembling Nios II Program
Hello everyone, I'm encountering an issue while trying to assemble a Nios II program using the Nios II Command Shell. The specific error message I receive is: ``` nios2-elf-as.exe --gstabs -I "C:/...
aikeu
2 years ago- csnsssn2 years ago
Hi Aik Eu,
Thank you for your suggestion.
I ran the Nios II Command Shell as you advised. I have also tried using the older version of the monitor program (version 18.1), and it successfully compiled the program. However, the issue persists with the newer version (21.1), and I'm still encountering the same error.
Any further guidance or suggestions would be greatly appreciated.
Thank you for your help!
