PNam01's avatar
PNam01
6 years ago
help me
Error: (vlog-13069) Waveform2.vwf.vt(30): near "-": syntax error, unexpected '-', expecting "SystemVerilog keyword 'import'" or ';' or '#' or '('.
# End time: 11:25:03 on May 18,2020, Elapsed time: 0:00:01
# Errors: 1, Warnings: 0
# ** Error: c:/
  • Hi Pham,
    Could you please let me know which are the sequence that you follow to get into this error?
    Next question, you are compiling or using an example design or your own design?
    Could you share all the transcript or the source code for reproduce the error? Because when you get this type of errors it is because the error is inside the code, not in the .vwf.
    Isaac.
  • Hello Pham,
    Did you find the solution for your issue?
    Isaac.
