JMccu10
7 years agoHello, Why are unused LEDs dimly lit but the rest of the FPGA is working as expected? What is the best way to ensure all unused LEDs are off? Thank you, Jeremy
The code is working fine except that LEDs [9:1] are dimly lit. I am using the free software - Quartus Prime Lite 18.1 and the ModelSim. module Mux_4_to_1 (Mux_Out, Sel, Mux_In); input [1:0] Sel;...
- 6 years ago
You have to solder the JP5 2-pin header only if you are using the dual image boot function on the DE10-Lite board
KhaiChein_Y_Intel
7 years agoHi,
Could you try to use the demo design and replace the design files with your design to see if this is the settings problem?
