JMccu10
7 years agoHello, Why are unused LEDs dimly lit but the rest of the FPGA is working as expected? What is the best way to ensure all unused LEDs are off? Thank you, Jeremy
The code is working fine except that LEDs [9:1] are dimly lit. I am using the free software - Quartus Prime Lite 18.1 and the ModelSim. module Mux_4_to_1 (Mux_Out, Sel, Mux_In); input [1:0] Sel;...
- 6 years ago
You have to solder the JP5 2-pin header only if you are using the dual image boot function on the DE10-Lite board
KhaiChein_Y_Intel
7 years agoHi,
The example design is the example mentioned in the user guide. As you mentioned, the demonstrations are working fine, I suppose it is not the problem of the LED.
May I request the design.qar file?
