rkaib
7 years agohello, how to read data in eclipse from a custom ip outputs?
Ahmed_H_Intel1
7 years agoHi,
In the platform Designer you defined your custom IP addresses, one of them for example is a control register and other is the IP memory. You should see these addresses in the system.h header file in Eclipse. You can simply point to these addresses and read/write.
Please let me know if you have any concern or need more support.
