rkaib
7 years agohello, can anybody tell me how to use alt_up_video_dma_draw function in quartus 2018
Deshi_Intel
7 years agoHi,
I am assuming your design configured all the IP setting correctly and there is no design timing closure concern else this is the first step that you need to check.
- For instance, if you drill further into VGA_Subsystem then it should show you the exact IP name that can match back with "video IP suite" doc
For the onchip memory issue debug
- Have you managed to isolate the issue is with memory write issue, memory read issue or memory content corruption issue or VGA display IP issue ?
For memory write/read issue :
- Memory write/read issue could be due to address mapping issue or design timing closure issue
For memory content corrupted issue :
- How do you generate the onchip memory hex file content ?
- Do you have other hex file content that you can load into to compare video output result ?
For VGA display IP issue :
- You want to checkout video IP suite doc to ensure you configure all the setting correctly that match with your hardware board
- You can also keep your design simple for debug to slowly disable IP feature in VGA subsystem to find out where is the culprit.
dlim
rkaib
7 years agothank you dlim,
thanks for all this effort,
I will double check these points one by one and keep you updated as soon
as I can, regards
