VenuBusani
3 years agoHeatsink requirement
Hello team,
In our design we are using the altera/intel part EP1K50FI256-2. Since this is BGA package and assemble in closed module can you please suggest the recommended heatsink for this part
Farabi_Altera
3 years agoHello,
Pls refer to document : https://docs.rs-online.com/b319/0900766b809b8276.pdf
and go to page 121 to get package dimension.
the dimension is 27 x 27 (mm) and you may want to search for heatsink same as this dimension so it can fit.
You can use the fin type heatsink if your application is running at higher speed.
regards,
Farabi
