8 years agoGPIO Pin Problems
Hi all, I am attempting to interface an ultrasonic range sensor with the DE2 board through the GPIO expansion header. The device has 4 connections, 5v vcc, ground, trigger, and echo. The 5v and gr...
8 years agoHi Digitalsolace,
1.Write a simple logic and connect it to the pin required and check(switch to header). 2.Re-create the project and check. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
