8 years agoGPIO Pin Problems
Hi all, I am attempting to interface an ultrasonic range sensor with the DE2 board through the GPIO expansion header. The device has 4 connections, 5v vcc, ground, trigger, and echo. The 5v and gr...
8 years agoHi Digitalsolace, Do you have (project_name).qsf.bak file in you directory of the working project? if so, You can import and use IT. Download the resources website. OR go to schematic and find the pin. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
