17 years agoGenerate Triangular Wave Table
Hello! I'm doing a project at school using the DE2 board as the digital controller of a DC-AC inverter. The goal is to output a 120V 60Hz sine wave from a ~300VDC input. Right now the des...
16 years ago --- Quote Start --- Hi, Things are done in different ways. For a triangular wave I will use a counter. It is easy but there are some subtleties. Remember the period of your wave = Fs/60 where Fs is your clk frequency or enable frequency. To get things clean and without dc offset I can use Fs of 6KHz then the period = 100 so I can use an 8 bit counter that goes from (-125 to 125) and back incrementing/decrementing by 5. (check that your ADC uses 2'Scomplement) The following untested code gives you the idea of getting 100 samples per period: The wave goes from -125 to 125 (51 samples) then 120 to -120 (49 samples) signal count : signed(7 downto 0); ------ process(reset,clk) -- assuming clk = 6KHz if reset= '1' then count <= -125; updown <= '0'; elsif rising_edge(clk) then if updown = '0' then if count < 125 count <= count + 5; end if; if count = 120 then updown <= '1'; end if; else -- if updown = '1' then if count >-125 count <= count - 5; end if; if count = -120 then updown <= '0'; end if; end if; end if; end process; output <= std_logic_vector(count); --- Quote End --- Hi, I've been trying to generate a triangular wave that can go up to 76, based on your example. The waveform goes up to 64, then goes down with negative values until a point then goes to 63 to count down properly. What could be the problem ? P.S :See attached file
