14 years agoFSM trouble
I am trying to understand and get working a FSM that is part of a PS/2 mouse lab I am working on. The first always block is not giving me any errors now even though I am not sure that the logic is c...
14 years agohere is the working FSM. I like this better as it is easier to see the output states along with the state priority in one shot.
reg [7:0] Rps2_command; reg Rps2_send_command; assign ps2_send_command = Rps2_send_command; assign ps2_command = Rps2_command; /***************************************************************************** * Finite State Machine(s) * *****************************************************************************/ // This FSM resets the PS/2 device and then keeps track of packets, which // consist of three data bytes. Packets could be from a key board or mouse, // but this code is needed only for tracking movements of the mouse. always @(y_Q, was_sent, ps2_data_en, plugged_in, ack_received) begin: state_table case (y_Q) S0: begin Rps2_send_command <= 1'b1;//S0 output values Rps2_command <= 8'hF4; mouse_packet <= 1'b0; if (was_sent==1'b1)//state priority 1 Y_D<=S1; else Y_D<=S0;//state priority 2 end S1: begin Rps2_send_command <= 1'b0;//S1 output values Rps2_command <= 8'hF4; mouse_packet <= 1'b0; if (ack_received==1'b1)//state priority 1 Y_D= S2; else Y_D= S1;//state priority 2 end S2: begin Rps2_send_command <= 1'b1;//S2 output values Rps2_command <= 8'hF4; mouse_packet <= 1'b0; if (ps2_data_en==1'b1)//state priority 1 Y_D= S3; else Y_D= S2;//state priority 2 end S3: begin Rps2_send_command <= 1'b1;//S3 output values Rps2_command <= 8'hF4; mouse_packet <= 1'b0; if (plugged_in==1'b1)//state priority 1 Y_D= S0; else if (ps2_data_en==1'b0)//state priority 2 Y_D= S3; else Y_D= S4;//state priority 3 when plugged_in==0 and ps2_data_en==1 end S4: begin Rps2_send_command <= 1'b1;//S4 output values Rps2_command <= 8'hF4; mouse_packet <= 1'b0; if (plugged_in==1'b1)//state priority 1 Y_D= S0; else if (ps2_data_en==1'b0)//state priority 2 Y_D= S4; else Y_D= S5;//state priority 3 when plugged_in==0 and ps2_data_en==1 end S5: begin if (!plugged_in) mouse_packet=1'b1;//S5 output values if (plugged_in==1'b1)//state priority 1 Y_D= S0; else Y_D= S4;//state priority 2 end default: Y_D = 3'bxxx; endcase end // state_table
