Ono
5 years agoFractional mode of altera_fir_compiler_ii
altera_fir_compiler_ii version 18.0 What is the configuration in Fractional mode? Is "Up sampling→LPF→Down sampling"?
In the Frequency Response (Magnitude) graph of the cofficients tag, It is di...
SengKok_L_Intel
5 years agoHi,
When you choose fractional rate, it allows you to configure both interpolation factor and decimation factor for either up or down sampling conversion.
Regards -SK
- Ono5 years ago
For example, Interpolation 3
If the decimation is 2,LPF processing is performed before decimation (Up sampling → LPF → Down sampling) and after (Up sampling → Down sampling → LPF).
Which will you be?
