10 years agoFPGA to HPS Communication
Hi Friends, I have the Terasic DeE-0 Nano Development board with Cyclone V and ARM Cortex HPS. As a part of my project, I have send some huge amount of data ( in megabytes ) from FPGA to HPS and s...
10 years agoHi Tazz1984,
Thanks for your reply. I have read the document. Unfortunately the document stresses more on Nios II processor, in my case in not much useful. I have some huge chunks of data and using Nios will again slow down my system. Its hard to find any example with HPS DMA as you suggested. I understand the theory behind it, but I am new in hardware design. How can I use the generated VHDL module and send these DMA signals. For eg, I have instantiated ( attached screeshot ) the DM controlled via Qsys and connected it to the HPS_SDRAM via Avalon interface. Now how will I use it ? through which inputs I should send the DMA commands and data ? . I tried in google all, but unfortnaltey could not find an answer. The following are the generated interfaces. component FPGA2SDRAMSCDMA is
port (
clk_clk : in std_logic := 'X'; -- clk
memory_mem_a : out std_logic_vector(12 downto 0); -- mem_a
memory_mem_ba : out std_logic_vector(2 downto 0); -- mem_ba
memory_mem_ck : out std_logic; -- mem_ck
memory_mem_ck_n : out std_logic; -- mem_ck_n
memory_mem_cke : out std_logic; -- mem_cke
memory_mem_cs_n : out std_logic; -- mem_cs_n
memory_mem_ras_n : out std_logic; -- mem_ras_n
memory_mem_cas_n : out std_logic; -- mem_cas_n
memory_mem_we_n : out std_logic; -- mem_we_n
memory_mem_reset_n : out std_logic; -- mem_reset_n
memory_mem_dq : inout std_logic_vector(7 downto 0) := (others => 'X'); -- mem_dq
memory_mem_dqs : inout std_logic := 'X'; -- mem_dqs
memory_mem_dqs_n : inout std_logic := 'X'; -- mem_dqs_n
memory_mem_odt : out std_logic; -- mem_odt
memory_mem_dm : out std_logic; -- mem_dm
memory_oct_rzqin : in std_logic := 'X'; -- oct_rzqin
sgdma_0_csr_irq_irq : out std_logic -- irq
end component FPGA2SDRAMSCDMA;
u0 : component FPGA2SDRAMSCDMA
port map (
clk_clk => CONNECTED_TO_clk_clk, -- clk.clk
memory_mem_a => CONNECTED_TO_memory_mem_a, -- memory.mem_a
memory_mem_ba => CONNECTED_TO_memory_mem_ba, -- .mem_ba
memory_mem_ck => CONNECTED_TO_memory_mem_ck, -- .mem_ck
memory_mem_ck_n => CONNECTED_TO_memory_mem_ck_n, -- .mem_ck_n
memory_mem_cke => CONNECTED_TO_memory_mem_cke, -- .mem_cke
memory_mem_cs_n => CONNECTED_TO_memory_mem_cs_n, -- .mem_cs_n
memory_mem_ras_n => CONNECTED_TO_memory_mem_ras_n, -- .mem_ras_n
memory_mem_cas_n => CONNECTED_TO_memory_mem_cas_n, -- .mem_cas_n
memory_mem_we_n => CONNECTED_TO_memory_mem_we_n, -- .mem_we_n
memory_mem_reset_n => CONNECTED_TO_memory_mem_reset_n, -- .mem_reset_n
memory_mem_dq => CONNECTED_TO_memory_mem_dq, -- .mem_dq
memory_mem_dqs => CONNECTED_TO_memory_mem_dqs, -- .mem_dqs
memory_mem_dqs_n => CONNECTED_TO_memory_mem_dqs_n, -- .mem_dqs_n
memory_mem_odt => CONNECTED_TO_memory_mem_odt, -- .mem_odt
memory_mem_dm => CONNECTED_TO_memory_mem_dm, -- .mem_dm
memory_oct_rzqin => CONNECTED_TO_memory_oct_rzqin, -- .oct_rzqin
sgdma_0_csr_irq_irq => CONNECTED_TO_sgdma_0_csr_irq_irq -- sgdma_0_csr_irq.irq
Thanks in advance
