10 years agoFPGA to HPS Communication wth External Avalon
Hi Friends, I have the Terasic DeE-0 Nano Development board with Cyclone V and ARM Cortex HPS. As a part of my project, I have send some huge amount of data ( in megabytes ) from FPGA to HPS and...
10 years agoHello,
Yes, the the f2h_sdram_data is the Avalon slave. I connected the Avalon_master of the bridge to this slave port. I am able to connect, but only problem is the memory mismatch. Could you please tell what do you mean by "Does it really need 32 bit address width" ? Do you mean the slave requires the 32 bit address width ? if so, no the maximum can be configured is 29 bits. But even though, how will I connect these two ports. Is there any documents tutorials for this ? I could not find anything which shows Qsys configuration,unfortunately. Best Regards.
