16 years agoFPGA programma
Hallo. In the line: assign is something wrong. What is the right way for this line? Thanks. JackR. module Lab3 (s ,x ,y ,m ); input s; //[1:0] s; werkt niet.Geeft s,s0 en s1 ...
16 years agoHallo amilcar.
Thanks for the replay. It is for a eight-bit wide 2 to 1 multiplexer. Figure 3. An eight-bit wide 2-to-1 multiplexer. 1. Create a new Quartus II project for your circuit. 2. Include your Verilog file for the eight-bit wide 2-to-1 multiplexer in your project. Use switch sw 17 on the DE2 board as the s input, switches sw7−0 as the x input and sw15−8 as the y input. Connect the swswitches to the red lights ledr and connect the outputm to the green lights ledg7−0. 3. Include in your project the required pin assignments for the DE2 board. As discussed in Part I, these assignments ensure that the input ports of your Verilog code will use the pins on the Cyclone II FPGA that are connected to the sw switches, and the output ports of your Verilog code will use the FPGA pins connected to the ledr and ledg lights. 4. Compile the project. 5. Download the compiled circuit into the FPGA chip. Test the functionality of the eight-bit wide 2-to-1 multiplexer by toggling the switch. Hope this wil help. Thanks, JackR.
