> Can you please share a screenshot of the Monitor Program after clicking okay to the "Download System - Partial Success" dialog box seen in the screenshot that you already posted?
It looks like "Download System - Partial Success" was the last words from "Intel FPGA Monitor Program".
Please find attached the requested screenshot, arm_de10_nano_asm-Mar-01-2021.jpg.
> I am a member of the Intel FPGA Academic Program team which created the Monitor Program
Just out of curiosity, do you or your department has access to a De10-Nano board and the "Intel FPGA Monitor Program" running on a computer with a USB port.
BTW, the subject now is changed to 'FPGA Monitor Program 18.1 Tutorial: "Download System - Partial Success" '
phiho
The Monitor Program did download the circuit. Please try compiling and downloading the program. If that succeeds, then you will be able to run the program.
Yes, we do have access to the board and the Monitor Program, but we cannot reproduce this issue.
Kind regards,
Blair
- phiho4 years ago
Please advise how to achieve this.
This is good to know. It is much appreciated if you would share your project file, the assembly source files and specify which version of Quartus and "Intel FPGA Monitor Program" you were using, the steps you performed, the screenshots and the messages in the "Info & Errors" panel after the run.
My project, "arm_de10_nano_asm.amp" contains two assembly programs: "simple_program.s" and "address_map_arm.s".
When I run "Actions/Compile&Load" I got "Loading errors".
Please find attached a screenshot and the "Info&Errors" messages.
It looks like we went the full cycle, back to where we started with the subject line: "Could not query JTAG Instance IDs". Should I change the subject line again or we all know too well what the problems are?
phiho
- phiho4 years ago
Hello Blair,
It is hoped that the attached screen shot and "Info&Errors Messages" came through. Please advise if you need them resent or do you need any further information to resolve this issue which was first reported 01-23-2021 02:00 AM.
Looking forward for your advice.
phiho
