FPGA Monitor Program 18.1 Tutorial: Could not query JTAG Instance IDs. Please ensure the FPGA has be
Responding to your original post. Is the monitor program installed on a different drive versus the project which seems to be on the F: drive? It may be that there is an issue with the monitor program handling of this scenario.
Kind regards,
Blair
- phiho5 years ago
It is assumed that you were able to reproduce the problem. Please confirm that you successfully finish the task with the project and the FPGA Monitor program on the same drive (which drive).
Please also advise if you used the default boot micro SD card comes with the board or the SD card with boot image from the installation of the FPGA Monitor program and how did you connect the micro and mini USB ports to the computer.
phiho
