Abdush
4 years agoFPGA for ETHERNET and SSF transceivers ?
Hi dears I wish you a good day , I am working on my bachelor graduation prohect which is ( an overcurrent protection relay design ) and I using an MPU to have all the functions and required controll...
Kshitij_Intel
4 years agoHi,
To implement 10/100/1000 Mbps Ethernet (RGMII) and Optical Transceivers with 1000BASE.
Which FPGA development board should I use? -- You can use Cyclone V SoC Development Board.
Which software should I use to design the FPGA? -- You can use Quartus for targeting Cyclone V SoC.
Sharing the reference design with targeting Intel Cyclone V SoC It has 2 Ethernet Media Access Controller (EMAC) peripherals embedded along with the A9 core in the Hard Processor System (HPS). Each EMAC can be used to transmit and receive data at 10/100/1000 Mbps over Ethernet connections in compliance with the IEEE 802.3 specification.
Cyclone V RGMII Example Design
Thank you
Kshitij Goel
