17 years ago
Four Bit Ripple-Carry Adder Circuit DE1
I've got some of the code from the website and some from my own from a Full Adder Circuit.It seems like my code is mixed up as when i insert output A or B,instead of having a sum,i have an output.This is wrong according to the truth table.Can anyone have a look at my code?
LIBRARY altera;
USE altera.maxplus2.carry;
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
LIBRARY WORK;
USE WORK.usr_def.ALL;
ENTITY chiong3_1 IS
PORT(
x_in : IN STD_LOGIC_VECTOR(3 DOWNTO 0);
y_in : IN STD_LOGIC_VECTOR(3 DOWNTO 0);
c_in : IN STD_LOGIC;
sum : OUT STD_LOGIC_VECTOR(3 DOWNTO 0);
c_out : OUT STD_LOGIC;
red : OUT STD_LOGIC_VECTOR(8 DOWNTO 0));
END chiong3_1;
ARCHITECTURE struct OF chiong3_1 IS
SIGNAL im : STD_LOGIC_VECTOR(2 DOWNTO 0);
SIGNAL imi : STD_LOGIC_VECTOR(2 DOWNTO 0);
BEGIN
red <= c_in & y_in & x_in;
c0 : full_add --1st starting fa
port map (x_in(0),y_in(0),c_in,sum(0),im(0)); --im(0) is c1
c01 : carry
port map (im(0),imi(0));
c : for i in 1 to 2 generate
c1to2: full_add
port map (x_in(i),y_in(i),
imi(i-1),sum(i),im(i));
c2to3: carry
port map (im(i),imi(i));
end generate;
c3 : full_add
port map (x_in(3),y_in(3), --last starting fa
imi(2),sum(3),c_out); --im(2) is c3
end struct;
Library ieee;
PACKAGE usr_def IS
COMPONENT full_add
PORT(
A,B,carryin : IN STD_LOGIC;
carryout,sum : OUT STD_LOGIC);
END COMPONENT;
END usr_def;
Library ieee;
use ieee.std_logic_1164.all;
entity full_add is
port(A,B,carryin :in std_logic;
carryout,sum:out std_logic);
end full_add;
architecture behavior of full_add is
begin
sum <= A xor B xor carryin ;
carryout <= (A and B) or ( B and carryin) or (carryin and A);
end behavior;
