18 years agoFlash Memory and SRAM data pin assignment
Hi, I'm having problem in assigning pins in using flash memory and SRAM. In my sopc, I'm using one avalon mm tristate bridge to link to the SRAM and Flash. Im not sure where should I assign th...
17 years agoI'm having the same problem with Cyclone III Development Kit. Using 2 tri-state bridges connected to a SSRAM and FLASH.
I would certainly need a step-by-step guide to do this. I've been fiddling with this for some time now :mad: Do I specify the shared pins in the Pin Planner? Thanks in advance!
