error when adding and using my own library in modelSim?
I have the same problem as the question here but the solutions still not working for me
SO I have my modelsim files in Desktop/FPGA/Altera/filter
then I added my_lib.all as :use work.my_lib.all and my_lib is in work and also in folder filter but still same error.
I changed it to : use filter.my_lib.all and still says filter is unknown!
I feel like I do not know how to manage files in modelsim too, is there a tutorial on it?
Can you upload a full message of the errors?
On ModelSim, go to Help->PDF Documentation -> User's Manual. You can refer to Chapter 3 Design Libraries.
Or you can go to Help->PDF Documentation -> Tutorial. You can refer to Chapter 5 Working with Multiple Libraries.
Nurina
- Nurina
Nurina
- TarikTec
Thank you, I have found the problem which was the name where I saved it.
Thank you for the two very important links, very important for beginner like me
- Nurina
Nurina
PS: If you find any comment from the community or Intel Support to be helpful, feel free to give Kudos.
