15 years agoError: (vcom-7) Failed to open design unit file in MODELSIM
I got this fail in Modelsim. What's this' solution, do you know? My fails are: error: c:/altera/91/modelsim_ase/win32aloem/vcom failed and error: (vcom-7) failed to open design unit file "../design/common/jpeg_pkg.vhd" in read mode.2 Replies
1. Your path have space in it. For example, my_work is OK, my work is not
2. File under read does not exist in the path - Altera_Forum
I know this is quiet old post, but I am also facing the same Error like below from QuestaSim. Can you please let me know, how you were able to fix this Error. Thanks much. --- Quote Start --- Hi, I got this fail in Modelsim. What's this' solution, do you know? My fails are: error: c:/altera/91/modelsim_ase/win32aloem/vcom failed and error: (vcom-7) failed to open design unit file "../design/common/jpeg_pkg.vhd" in read mode. --- Quote End ---
