16 years agoerror to every NIOS II project
Hi, i have the DE2 board and i try to run on this many programs and demonstrations from system CD, some programs run, but programs using the NIOS II at the building process gives erros... ...
16 years agoyes, thas all.
open the project. open SOPC tool. and press regenerate. *regeneration will rebuild the project with the same settings for hardware (nios and other) but with new settings for database project (settings for the appropriate version). if you continued to have problems try to work in XP OS.
