16 years agoerror to every NIOS II project
Hi, i have the DE2 board and i try to run on this many programs and demonstrations from system CD, some programs run, but programs using the NIOS II at the building process gives erros... ...
16 years agoProblems:
there were two different problems. The first was an incompatibility between NIOSII and VISTA. when I worked in XP OS problem was that the project had been built in different SOPC Edition. Solution: i open the project with Quartus and regenerate SOPC with each version. and then, the project version was compatible with Quartus-NIOS version.
