14 years agoError: couldn't execute "qwedt"
Hi, I'm using Quartus II 64-Bit Version 10.1 with Altera U.P. Simulator Version 10.1 After I select File > New Simulation Input File, get the following error message: error: couldn't...
14 years agoI had the same problem. Turns out you need to make sure that quartus_sh.exe is run from the altera\10.1sp1\ quartus\bin\ directory NOT the \bin64\ directory. Then it should be able to find the qwedt.exe just fine. Should work with quartus 10.1 as well (no sp1).
-Matt
