14 years agoError: couldn't execute "qwedt"
Hi, I'm using Quartus II 64-Bit Version 10.1 with Altera U.P. Simulator Version 10.1 After I select File > New Simulation Input File, get the following error message: error: couldn't...
14 years agoTry running qwedt outside of qsim. If it installed properly, it should be in the <quartus installation>\quartus\bin or quartus\bin64 directory.
If it's not installed there, you will probably need to re-run the UP installer.
