17 years agoEPC1 with UP2
can i load a configuration program onto EPC1PI8 (EPC1) by using the UP2 board (ie.byteblaster 2), or do I need someother hardware to program EPC1PI8 (EPC1).
17 years agoI had to dig rather deep to find a documentation...
Actually, UP2 doesn't provide on board programming of an EPC1 device. As far as I understood, EPC1 configuration device is an option, that wasn't included with the Dev Kit. However you can assemble an adaptor consisting of a DIL8 socket, a JTAG/AS 10p. header and a 5V power supply. A ByteBlaster-II or USB-Blaster is required for AS programming, ByteBlaster or ByteBlaster-MV don't work. Alternatively, other dedcated programmers should be able to program this type of SPI serial flash.
