Enabling UVM in Modelsim 2020.1
This previous forum post https://community.intel.com/t5/Intel-FPGA-Software-Installation/Modelsim-ASE-starter-not-directly-support-UVM/m-p/1288356 probably can help you out:
Unfortunately ModelSim does not have pre-compiled UVM features. You are probably thinking of Questa Sim.
And you'll need to compile the uvm_pkg as well. For example,
vlog -work work -sv -stats=none C:/work/ST/simulation/tb_captur_1.sv <uvm_pkg path>/uvm_pkg.sv +incdir+<UVM source path>/src
This is another related link https://blogs.sw.siemens.com/verificationhorizons/2011/03/08/using-the-uvm-10-release-with-questa/:
If you use an earlier Questa installation, like 6.6d or 10.0, then you must supply the +incdir, and you must compile the UVM.
Sheng
