10 years agoeclipse tool-chain settings to match monitor program
Hi...has anyone tried editing the tool-chain/settings in eclipse to make project in IDE environment instead of using "Monitor Program"...most of the time I use eclipse to edit code and for my DE1-SoC...
10 years agoSorry, my mistake. I should have thought of HPS when you said you were using the De1-SoC board. The compiler you mentioned is for linux applications. I don't know if it makes any difference, but you might try the bare metal compiler arm-altera-eabi-gcc. It is located in <altera directory>\embedded\host_tools\mentor\gnu\arm\baremetal\bin
