17 years agoDynamic Power of Multiplexer
As you may know, dynamic power is caused by the switching activity in your design, and the switching activity pretty much depends on the operation/clock frequency. I try to measure dynamic power of a...
12 years agoThe SAF (Signal Activity File) seems out of date now and is format of quartus so called simulator. If you generated proper VCD then can't you just enter it in power analyser?
