Mathiazhagan
4 years agoDifference between IP Catalog and Component Editor in Platform Designer
Hi all,
I have a question on what is the difference between IP catalog in quartus and component editor in platform designer in intel, Both have in built IPs but while configuring those IPs there is...
- 4 years ago
Right. There are some differences between IP catalog and component editor on parameters configuring but both can be used. You can choose which one to use based on what parameters you want to customize. Obviously, platform designer got more configuration features.
When you generate HDL, enable Create block symbol file (.bsf) feature under synthesis to create block symbol file.
Sheng
ShengN_altera
4 years agoMay I know any update or Should I consider that case to be closed?
