Difference between IP Catalog and Component Editor in Platform Designer
- 4 years ago
Right. There are some differences between IP catalog and component editor on parameters configuring but both can be used. You can choose which one to use based on what parameters you want to customize. Obviously, platform designer got more configuration features.
When you generate HDL, enable Create block symbol file (.bsf) feature under synthesis to create block symbol file.
Sheng
Sheng
