fpga_nick
1 year agoDid I need to set a proper pin assignment if I running a simulation ?
I am trying to run a design example simulation for AGIB027R29A1E2VR3, F-tile. Quartus version v23.3 , Questasim 2023-2. But the target devkit with proper pin selection only available for F-series...
- 1 year ago
For running simulation, pin assignment is not required, but you may need to run synthesis.
Using your environment I am able to run the simulation passing the ld_debug.
Please check back the step, Normally the fail will occurs if your host is out of memory, the full simulation of "run -all" normally took few GBs on the memory space, I suggest to try clear the memory before re-run
Wincent_Altera
ShengN_altera
1 year agoHi,
May I know which design example and document you're following?
Sheng
fpga_nick
1 year agoAgilex I-series ES device targeted F-tile Avalon Streaming Example Design.
