10 years ago
demonstration of parallel operation of fpga
Hi everyone,
am a beginner in the FPGA technology, i presently have the cyclone-lll DE0 FPGA board from Altera.
If i design simple programs, like a counter and a multiplexer. How do i load the programs and run them simultaneously on the FPGA to demonstrate the parallel advantage of the FPGA??
    if you have multiple entities which you want to run in parallel they need to be compiled together, but since you are kust beginning I would only do that when the tutorials you may follow do that.
    --- Quote Start ---
    First of all - an FPGA does not run "programs" - it compiles your HDL (hardware description language) code and coverts it to a digital circuit.
    To see something running in an FPGA - compile your code - and then you can download the .sof file directly to the FPGA via a JTAG cable. Altera provides many tutorials on how to use Quartus and FPGA dev boards:
    https://www.altera.com/support/training/university/materials-tutorials.html
    --- Quote End ---
    thanks for your response pietervanderStar, i will go through the materials-tutorials and, will contact you if i need further assistance in the compilation of separate entities.
