13 years agoDedicated clock pin on DE2
Hi Is there a way to get a clock signal from an external device into any PLL clockin on the DE2? I've read that those clockin must be from a dedicated clock, but if I search in the manual ...
13 years ago --- Quote Start --- Is anything else for configuration to use this for the PLL? I mean, I've created a PLL with the megafunction where do I tell it to use CLK7 or its just by setting the PLL clockin port to CLOCK_EXT in the pin planer? --- Quote End --- You can call the clock port/net anything you like, just so long as you set the pin to P26. For example, I call it clk_sma in my top-level design file. You then connect that net name as the clock input to your PLL megafunction instance. I would recommend creating a counter and use it to blink an LED once per second. If you have the PLL configured correctly, then it'll be pretty obvious. This thread: http://www.alteraforum.com/forum/showthread.php?t=33462 has an example zip file called de2_basic.zip. Download it and follow the instructions. It doesn't have a PLL in the example, but you could add it easily enough. Cheers, Dave
