13 years agoDedicated clock pin on DE2
Hi Is there a way to get a clock signal from an external device into any PLL clockin on the DE2? I've read that those clockin must be from a dedicated clock, but if I search in the manual ...
13 years agoThanks dwh
My board says just DE2, so I'll use the SMA... Is anything else for configuration to use this for the PLL? I mean, I've created a PLL with the megafunction where do I tell it to use CLK7 or its just by setting the PLL clockin port to CLOCK_EXT in the pin planer? Thanks
