13 years agoDedicated clock pin on DE2
Hi Is there a way to get a clock signal from an external device into any PLL clockin on the DE2? I've read that those clockin must be from a dedicated clock, but if I search in the manual ...
13 years agoPlease review the schematic for the DE2. There are several versions of this board (DE2, DE2-70, DE2-115)
On the DE2, there is an SMA on the board, it connects to pin P26 which is called CLOCK_EXT in the schematic and connects to CLK7 on the FPGA. You should be able to use that. Cheers, Dave
