10 years agoDecimal Point on Seven Segment Display for DE2-115
Hi everyone, On the DE2-115 development board's 8 7-segment-displays, there are decimal points. There are, however, no FPGA pin numbers to access these decimal points--at least I can't find th...
Nicholas66
1 year agoTo enable the decimal point on the seven-segment display for the DE2-115, you need to check the control signal associated with the DP (decimal point) segment. Make sure your FPGA design includes it in the output mapping. Are you using Verilog or VHDL for implementation?
