17 years agoDE2 USB BLASTER doesn't work
my DE2 Board doesn't see programming cable (USB Blaster). USB Blaster is embedded in DE2 Board. my other Altera board works fine. Quartus recognize the USB Blaster as soon as I connect to the board. ...
17 years ago --- Quote Start --- DE2 doesn't have regular Altera Programming --- Quote End --- Yes, JP3 is an assembly option only. Also, the MAX CPLD image file apparently isn't supplied with DE2 support files. I simply assumed, this would be the case as with Altera Dev kits. --- Quote Start --- Is there any other power supply (5V)? --- Quote End --- It's an internal regulator and probably O.K. in your case. --- Quote Start --- how can I fix 93C46 configuration EEPROM corruption. --- Quote End --- I'm not aware of an official procedure, but it should work by copying the data from another DE2-board or an USB-Blaster using FTDI MProg tool. The problem has been reported by other forum users before. I wonder how an EEPROM corruption happens at all. It may be also the case, that the EEPROM data are O.K., but the FT245 initialization fails for some reason, e. g. inappropriate reset.
